Dual Countdown Timer
Old 04-14-15, 05:29 AM
johnam's Avatar
Received 12 Upvotes on 11 Posts
I can't find a dual countdown timer for a single 2 X 4 electrical box. I want to use it on a Panasonic bathroom vent/heater. I want to control the vent and heat independently. Thanks for your help.
Old 04-14-15, 05:56 AM
Norm201's Avatar
Received 716 Upvotes on 637 Posts
And I don't think you ever will. You'll need to install a bigger box that will take two timer/switches.
Old 04-14-15, 08:32 AM
ray2047's Avatar
Unless there is inadequate space installing a two gang old work box can be done easily without any Sheetrock repair needed. Do you already have a xx-3 (4-wire) cable installed? Does power come in at the switch?
Old 04-15-15, 06:12 AM
johnam's Avatar
I always look for the "easy way out" first. I just wanted expert advice so I guess I'll replace the box. Thanks.
