137 volts??!!
Old 04-14-15, 03:54 PM
137 volts??!!
Hello some track lighting in my house was flickering (turned out be just the cheapo led track lights) but that got me checking the voltage across the track and come to find out the track as well as everything on that phase has 137 volts Hot to neutral and hot ground and 0 volts neutral to ground and on the other phase everything has 139 volts hot to ground and hot to neutral and again 0 volts ground to neutral. I check with amprobe multi meter set check up to 200 volts AC. What could be causing this? Am I getting 137 and 139 volts from the power company? Is this a serious problem?
Old 04-14-15, 04:37 PM
pcboss's Avatar
Received 83 Votes on 71 Posts
Those reading are too high. As both legs are measuring the same I suspect a meter problem.
Do one leg go up while the other goes down if you turn something on?
Old 04-14-15, 04:51 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Check the meter in a receptacle at work or a friends house that is not on the same transformer.
Old 04-14-15, 05:18 PM
no 137 and 139 constant volts hot to neutral and hot to ground all the time unless the hot is switched and off of course
Old 04-14-15, 05:20 PM
Received 1,029 Votes on 955 Posts
That voltage is too high for a home. Either you do indeed have a high voltage problem or your meter is incorrectly reading high. (my bet is it's a meter problem)
If you take the meter to a friends house..... try it there and see what it reads.
Old 04-14-15, 05:22 PM
ray2047's Avatar
If this is a digital meter replace the batteries before checking it as I suggested above.
pcboss's Avatar
You still need to see if you get voltage swings under load to rule out a neutral issue.
Old 04-14-15, 05:25 PM
I have tested the track light with lights on it and outlet with something plugged into the other outlet of the pair .How would I check the volts of something plugged in?
Old 04-15-15, 12:16 AM
F
Received 35 Votes on 27 Posts
You still have not told us if you (a) changed the batteries in your multimeter or (b) have taken the meter to a different house to test the voltage. My initial assumption based upon what you HAVE told us is that your meter is reading incorrectly. Until that supposition can be completely eliminated no one can offer any substantial help.
Old 04-15-15, 03:00 AM
I posted this last night so will check my meter some where else today and replace batteries.
Old 04-15-15, 06:49 AM
ray2047's Avatar
So it is digital not analog? (Batteries in an analog are only for resistance measurement.)
Old 04-15-15, 07:53 AM
I
Received 43 Votes on 41 Posts
If your meter reads normal voltage elsewhere (around 120V), and with new batteries your meter is still reading ~140V in the home, then you need to call your power company's emergency repair number. This problem would be entirely their problem and they should fix it at no charge to you. If any of your stuff was damaged, they may be liable for some replacement cost.
Old 04-15-15, 09:31 AM
B
Received 1 Vote on 1 Post
Same thing happened to me a few years ago, computer shut down from high voltage. Checked with my kill-a-watt and it showed 132 or 134 volts, same thing at the neighbors.
Power company stopped by and checked, yep, too high. Left in his truck for about 20 minutes and stopped back and checked again, 120 volts. All he said was you're set to go, thanks for calling.
No idea what he did, wish I would have asked him.
