Simple switch to select from 2 110v power supplies
Old 04-15-15, 11:43 AM
K
I am looking to install a fridge in my cargo trailer and run it off my truck battery (inverted to 110-v) when in transit, and then run it off of shore power when at the destination. Is there a simple switch box out there that I can install to select between the two power sources?
The only other option I can think of would be to install two outlets and physically switch the fridge plug between the two.
Old 04-15-15, 12:24 PM
I
Received 43 Votes on 41 Posts
You could put a 120V receptacle on your inverter and just move the shore power cord between the inverter outlet and the shore outlet. I like this method as it is seamless to also go to a generator. Or you could get a double-pole, double-throw (DPDT) switch and wire it up through that.
Old 04-15-15, 01:02 PM
K
Thank you ibpooks. I was unaware of the DPDT option. After reading your post googled DPDT Switch to get more information. Is there a reason why a single-pole, double-throw (SPDT) would not do the job satisfactorily?
Old 04-15-15, 01:25 PM
I
Both the hot and the neutral should be switched when you are transferring between "separately derived systems". This is one of the very few times a neutral should be switched.
Old 04-15-15, 07:02 PM
Justin Smith's Avatar
I'd be cautious what inverter you're using your fridge on. If it's not a pure sine wave inverter it could greatly shorten your fridge's lifespan. Depending on what you want to spend you could also use a DPDT contactor and wire the coil to the utility side.
Old 04-16-15, 08:56 AM
K
Since I only plan to make 10-12 trips a year with the trailer I am looking for something as economical as possible. Do you think the inverter will be an issue if it is used only 100 hrs/yr max? Sorry, but I am too much of a novice to follow/understand your recommendation.
