Need help with wiring
I have a 3 switch outlet box in master bathroom. The box has five 14/2 cables coming into ti.
#1 is the source cable from gfci in my garage
#2 is to a receptacle outside on my deck
#3 is to a shower light in bath
#4 is to a Fan/ Light combo in the bath
#5 unknown
If I hook up the #1 to #2,3,or 4 by themselves, they power the intended fixture.
If I hook the #1 up to #5 by itself it trips the gfci in the garage.
Any help as how to wire this box with the receptacle on the deck and the shower light protected by gfci.
#5 unknown
If this is new wiring it does not meet the code requirements for bathroom receptacles being on a dedicated 20 amp circuit. If it is existing the outside receptacle sounds like it is already downstream from the garage GFI.
Shower lights normally do not call for GFI protection.
I dont think I explained myself well. Here are some pictures to see the way i currently have it connected.Everything seems to be working properly like this, but obviously Im missing something because I have one cable thats not hooked up.
