Reload this Page >
Disconnecting part of box - do I need to ground the ground wire?
Old 04-15-15, 05:55 PM
P
Received 2 Upvotes on 2 Posts
So the previous owner did some weird wiring.... randomly adding new outlets, lights and wire runs.... I want to make some sense of it all and so I will be making "breaks" in some runs and re-routing some wires and adding new circuits to ensure optimal load per each circuit and separate some rooms that are now on single circuit.
My question is...if I have a box that I intend to make an end of a run by removing the outgoing wires - can I just use the screw-on-connectors to insulate the remaining 3 wires from the incoming cable and then close the box or do I need to somehow close the ground ?
I believe that insulating the individual wires before closing them off in an electrical box is sufficient - just to make sure they never contact each other and don't get loose....but I am not familiar with NJ codes
Thanks!
Old 04-15-15, 06:03 PM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
So it sounds like you want to abandon the end of the circuit,capping the wires as you suggested is fine,if it is a metal box the existing bond wire must be attached to the box with a ground screw or clip,the box must remain exposed with a blank plate in place.
Geo
Old 04-15-15, 06:08 PM
P
cool - thanks for super fast reply.
This is indeed metal box...what if it was a plastic box? do you then just cap the ground wire?
If so why not do it with metal box as well ?
After all, if the black and the white are perfectly insulated then the box can't become electrify
just trying to understand....thanks!
Old 04-15-15, 06:12 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
In a dead end plastic box the ground can be left folded up. Nothing needs to be done as the plastic is an insulator.
Old 04-15-15, 06:29 PM
ray2047's Avatar
[If plastic box] do you then just cap the ground wire?
Why? If he whole wire is bare the cap would insulate less then 10% of the wire.
Old 04-15-15, 06:53 PM
P
I know it sounded stupid but at the same time I have heard some weird requirements by local codes...so just wanted to make sure this is up to code....
Old 04-15-15, 07:41 PM
ray2047's Avatar
No question is stupid when you are learning and you are always learning.
Old 04-15-15, 09:23 PM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
Also if it's a metal box be sure to ground the box.
Old 04-16-15, 05:11 AM
A
Received 250 Upvotes on 230 Posts
If a cable is not withdrawn from the box then its ground wire may remain connected to the (metal) box and/or other ground wires in that box. Cap (or tape over) the ends of unused hot and neutral wires but do not twist together any two unused ends.
