FMC as ground path
FMC as ground path
AFAIK, 6' max with FMC.
Am I correct in that it's 20Amps max.
I live in BX land.....all that we use is bx to the panel.
If I plan to run FMC for a particular run, do they make it with the intergrated bonding strip ?
FMC has a grounding conductor pulled in with the circuit conductors. It does not use a bond strip.
