Magnetic motor starter
Have a model ECN0501BAA Nema 0 Non-Comb.
3phase 240 volt coil. This is for a 3phase motor. 3/4 HP 3.2 FLA.
what size heaters do I put in the starter and what would the Eaton part number be for the heaters?
It's like pulling teeth to find heater elements. The following chart should be what you need. I'd confirm when you order though to make sure.
