How do I wire outlets?
Old 04-21-15, 02:24 PM
G
Hello,
I am putting 3 wall outlets in my garage, running it straight from my breaker. Please take a look at my crappy drawing and tell me if I got it right, or if its REALLY not that simple.Name:  this thing.jpg
Old 04-21-15, 02:35 PM
Norm201's Avatar
Received 725 Upvotes on 641 Posts
You should use pig tails instated of direct wire from the power line.
Old 04-21-15, 02:39 PM
G
Do you mean like this?
Old 04-21-15, 02:59 PM
ray2047's Avatar
The receptacles need to be GFCI protected. They can be 15 amp receptacles even if the breaker is 20 amp. (Your picture shows 20 amp receptacles.) The wiring must be #12 if a 20 amp breaker is used..
Old 04-21-15, 03:15 PM
G
Yes I am using 12/2 wire.
Old 04-21-15, 04:20 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
Using the second diagram you would need two gfi receptacles. If the one is wired from the load terminals you only need one gfi. The ground would be the only pigtail.
