Outdoor Outlet Box
Old 04-23-15, 07:37 PM
Outdoor Outlet Box
Anyone know of any outdoor, flush-mount, boxes? All the ones I see stick out from the house. Thanks.
Old 04-23-15, 07:48 PM
Received 4,059 Upvotes on 3,642 Posts
What will you be installing the box in ?
You can use a standard cut-in gem box for installation into wood.
Old 04-23-15, 08:17 PM
pcboss's Avatar
Received 202 Upvotes on 176 Posts
Arlington has an in use box with cover that is close to flush.
Old 04-23-15, 08:34 PM
I was just going to cut a hole in my cedar siding. I have access to the rear of it since it's in the basement.
pjmax, is there some of cover or plate that would make it a little more waterproof?
Old 04-23-15, 08:43 PM
Piddler's Avatar
If you're putting this through an outside wall, the cover plate is what will make it weather proof. It should seal and cover the outlets. Just purchase the cover for the siding you have.
Old 04-23-15, 09:09 PM
Just about any of the in-use cover systems will fit over the cut-in gem box. A little bead of silicone around the top and two sides will keep the water out.
I believe pcBoss was referring to this style of box and plate where the plastic box gets cut into the wall.
Arlington DBVR1C-1 Outdoor Electrical Box with Weatherproof Cover for Flat Surface Construction - Amazon
Old 04-23-15, 09:42 PM
Piddler's Avatar
Very nice PJmax, I like those.
Old 04-24-15, 04:01 AM
pcboss's Avatar
That is the one Pete, thanks.
Old 04-24-15, 04:44 AM
Great, thanks............
Old 04-24-15, 11:30 AM
What about one of those blue old-work boxes from HD, would that work?
Old 04-24-15, 12:09 PM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
Yes. .................................
