Lake water pump trips breaker
Old 04-25-15, 07:43 PM
Hello
I seem to be having a problem with my lake fed waterpump breaker tripping.
This only started happening today after taking a shower I reset the breaker and I can hear the water filling up again and the pressure works fine for roughly 2 to 5 minutes as I run the water..
The pump cycles between 50-65 pounds pressure..and then.. Pop.. Breaker goes and pressure drops to 0 again.. Reset the breaker.. And same same..
Any recommendations?… I was thinking I should get electrician to come in and replace the 20 amp breakers..
Thank you all in advance
Matt
Old 04-25-15, 07:57 PM
ray2047's Avatar
Does the breaker feel hot when it trips? I don't suppose you have a clamp on amp meter?
Old 04-25-15, 08:03 PM
Before changing any circuit breakers you need to check the current draw of the pump motor and compare it to the nameplate rating. More likely you have a bad bearing in either the pump or the motor that is requiring more horsepower from the motor.
Old 04-25-15, 09:45 PM
ray2047's Avatar
If you have another breaker same amps and volts in the panel try swapping out as a test.
Old 04-26-15, 05:41 AM
I'd also check the foot valve/strainer for obstructions like seaweed or frogs, or some human debris. I once tried selling a lake cottage that had an eel sucked up into the intake pipe . . . . and that made the pump work harder. Kinks in black poly pipe can cause trouble too.
Old 04-26-15, 06:13 AM
CasualJoe's Avatar
Like an arm, leg or a few fingers?
Old 04-26-15, 07:04 AM
Originally Posted by CasualJoe
". . . Like an arm, leg or a few fingers? . . ."
I think those usually float, don't they ?
I was thinking more along the line of old fishing tackle, sandwich wrap, or lost garments . . . . but who knows ?
Old 04-26-15, 07:26 AM
No.. we dump the bodies on the other side of the lake..
So.. playing around today as I wait for my Plumber to call ON $$$SUNDAY..
If I keep the water flow, lower.. the pump works fine.. no breaker trip.. if I put the thing on FULL throttle and water is flowing t very healthy rate.. She pops..
not sure if that helps in determining.. but I will ask him to measure current ..and I do have a spare dual 30mp to replace the 20 amp installed.. I hope its not the pump in the lake... ummmmm...I am not even sure where it is ...lol
Old 04-26-15, 10:11 AM
ray2047's Avatar
Never replace a 20 amp breaker with a 30 amp breaker unless you want a fire.
Old 04-26-15, 10:24 AM
Noted with thanks very much
