Leviton 585 range hood switch
Old 04-26-15, 11:04 PM
B
BGC
BGC is offline
I have to replace the 2 speed fan switch on my range hood. New switch is Leviton model 585:
Single pole, pushbutton switch. 2 speed 3 position 3A-125V, 1A-250V.
New switch has 3 wires: black, red, blue.
The old switch has black, red, brown.
Can I assume: black wire to black wire, red to red and blue (from new switch) to brown wire (existing)?
Thanks
Old 04-27-15, 12:02 AM
Received 3,897 Upvotes on 3,494 Posts
I would agree with your choices. You won't hurt anything if the connections at the switch are incorrect.
Old 04-27-15, 04:44 PM
B
BGC
BGC is offline
Thanks for your response.
I connected the new switch as described above but, only get one speed from the fan. I either have a defective switch or the wiring is incorrect. The 585 switch is a push button. First push - nothing. second - full fan power. Third - off. I could swap connections - which color wire would not be changed, red or black? Thanks.
Old 04-27-15, 05:03 PM
ray2047's Avatar
Leave black connected to power in. That doesn't work you could map the switch using a multimeter set to ohms.
