Service drop from pole goes through trees
I'm looking to put an offer on a house. The service line coming from the electrical pole and directly to the house goes right through a 50' maple tree on the property. The tree coverage is something I really like about this property (it's only 0.12 acres).
Will the power company require me to cut down or mutilate this tree?
I would suggest you talk to the power company about if there is another place you can move the meter. It will probably cost you ± $1500 to do but it will be good for the tree you like.
Received 38 Upvotes
In my area the Poco mutilates the tree for free each year...
The poco doesn't really care here either. They keep up with trimming for the primary (high voltage) wires but a service wire thru a tree is your responsibility. You are encouraged to hire a competent tree company due to electricity.
In my area they wrap the triplex with what looks like a split PVC conduit and forget about it. If there's high voltage primaries, however expect to lose half or all of the tree.
Hi npeltier,
I did not born in US, but lived several years and still own a House in the Midwest (I can see that you are from that region too); however, I am currently (just temporarily and hoping to back soon to the States) living in the Caribbean... here the Government do not mutilate trees, they just totally destroy and remove them whenever they want at any place they want just for no reason... which in my opinion it should be classified as a crime; destroying them lack of total sense because here the temperatures raise over 100F with extremely high levels of Humidity, you suffocate on the Summer and the Sun will burn you alive during almost all the year round, therefore more and more trees are needed in the Caribbean but insanely the government just continue massively destroying them.
Regarding your situation with the power company and your tree, I will suggest to investigate if you can pay to have the meter moved as ray2047 suggested to you:
If that is possible, I will not doubt to pay those $1,500 to save a tree, specially if is a tree in the land and house I will live; that tree is life and if after all you have the money to buy a House I will highly recommend to make the extra inversion and save that tree as part of the house, it will turn into a lot of blessings and personal satisfaction now and in the many years to come.
Save that tree.
Thank you a lot.
Sincerely: Jos Lewis Von Sant.
Save that tree.
Thank you a lot.
In my area the Poco mutilates the tree for free each year and then you cross your fingers and hope it doesn't die before the next mutilation.
I would also suggest looking at getting the electrical service changed to underground. That would solve many problems. Again, this would be done by the power company up to the meter. Likely the meter would need to be changed but could stay in the same location.
Similar story in my area -- the power company doesn't trim trees on private property unless it is a primary voltage line. Maintaining trees around residential service drops is the responsibility of the home owner. They have a list of preferred tree trimming contractors who are certified to work around electrical wires.
However make sure you know where your property line is. On most city lots a reasonable portion of the front or side yard is actually city property especially between the side walk and the roadway. Trees in that area are trimmed by the power company.
Agreed with Tolyn as long as you can trench far enough from the tree to avoid killing it. Hard (Sugar) Maples can really be hurt by trenching too close. Soft maples are much more forgiving.
Locally when we pay for a new service hook up, overhead is the cheapest with a substantial upcharge for underground service. As far as I know our POCO doesn't allow anyone else to do the work ... but calling them should give you a good idea of who does the work and what it would cost.
but I really doubt most power companies will gladly volunteer to foot the bill.
I wouldn't worry.
In my city, the city owns the first few feet of your property from the front sidewalk. There is a tree in front of my grannie's house within this area. The street lights have overhead wires running light to light. Years ago one of these wires was visibly resting in the middle of one of the main branches where it y'd off. She called the city and they were unconcerned. The tree has now literally grown around that wire and the city is still unconcerned.
