Air compressor wiring
Old 04-29-15, 11:32 AM
K
I picked up an old craftsmen air compressor the other day. The motor on it is a 230 volt 5 horsepower. Now the motor turns on and works but the compressor seems to load it down and eventually overheats and trips out. Without the compressor belt motor runs fast and seems strong on its own. I'm questioning the wiring on this thing. It's wired for 110 outlet and has a 2 prong plug. But the motor looks like it doesn't wire up for 220.
Old 04-29-15, 12:06 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Residential voltages are 240 (occasionally 208) and 120. If it is a 240motor it can't be run on 120. Give us the model number or a link to a manual for it.
Old 04-29-15, 12:11 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Also furnish a picture of the wiring from the cord to the box on the compressor, with the cover removed, as well as a picture of the end of the cord (plug).http://www.doityourself.com/forum/el...your-post.html
Old 04-29-15, 12:42 PM
K
well I can't seem to upload anything. keep getting error message
Old 04-29-15, 12:50 PM
K
Size:  49.5 KBName:  138.jpg
Size:  46.1 KBName:  139.jpg
Size:  27.6 KBName:  140.jpg
Size:  37.1 KBName:  141.jpg
Size:  18.9 KB Had to resize go figure
Old 04-29-15, 12:53 PM
K
Old 04-29-15, 01:05 PM
Received 1,335 Votes on 1,234 Posts
That plug should be removed and replaced with a 240v type plug.
The receptacle needs to be replaced ASAP also. I can't believe someone would put a regular receptacle on 240vac.
That is a single voltage motor and can only run on 240vac.
Are you plugging it into a 120v receptacle set up for 120vac ?
Old 04-29-15, 01:42 PM
chandler's Avatar
The motor is 240 volt only, so changing the plug to a 240 one and supplying it with the proper voltage will probably do the trick. Pass & Seymour 20 Amp 250-Volt Ground Circuit Monitor Plug-PS5466XGCM - The Home Depot
Old 04-29-15, 02:25 PM
K
That's what I figured. Looks like time to install a 250 outlet in my garage. And require this thing.
Old 04-29-15, 02:43 PM
chandler's Avatar
You'll be running a 240 volt circuit, consisting of 2 hots and a grounding wire with 12-2 NM cable (marking the white wire on both ends with black tape) or equivalent in conduit to a 240 volt receptacle of 20 amps. Install the plug on the end of the compressor's cord to match the receptacle.
Old 04-29-15, 10:38 PM
K
Ok I'm slightly home electrical dumb. But good at figuring things out. I have no proper outlet in my garage. I was talking to my dad about it and took a look at my breaker box. Apparently I need to add another breaker for the outlet. How do I go about wiring it up?
Old 04-30-15, 12:03 AM
ray2047's Avatar
If the garage is attached you will install a 20 amp 240 volt (2pole) breaker in your breaker box. (Breaker must be listed for your panel.)
From the breaker box to your garage you will run 12-2 NM-b (AKA Romex). At the breaker box the black and white wires go to the breaker and bare wire to the neutral bar (or if a ground bar to the ground bar). The white wire will be remarked black or red with bands of tape or felt tip marker on both ends.
At the receptacle:
If the garage is detached then it is more complicated.
Old 05-02-15, 12:16 PM
K
Thanks for the advice. I wired up a new 220 outlet and plug and now the compressor works great. Even added another 110 outlet while I was at it. Was easier then I thought it would be. Feel way more confident about residential wiring.
Old 05-02-15, 12:46 PM
ray2047's Avatar
No, that was a 240 and 120 receptacle you added. Glad you got it. Thanks for letting us know.
Old 05-02-15, 12:50 PM
F
Received 36 Votes on 28 Posts
Good job!
Now train yourself to use the proper terms, 120 and 240 volts instead of the incorrect 110 and 220.
(I would have beat Ray if not for the three minute delay between posts. )
Old 05-02-15, 12:55 PM
ray2047's Avatar
You see one finger typing has its advantages. By the time I type it and correct it it is always more than 3 minutes.
Old 05-02-15, 08:00 PM
CasualJoe's Avatar
Received 97 Votes on 87 Posts
I've seen it done like that before......in a school!!
Old 05-04-15, 04:18 AM
E
Intrigued is you voltage that accurate? In the UK it was 240 volt but we harmonised with Europe so now 230 volt however when it was 240 it was plus/minus 6% but after harmonising it was plus 10%/Minus 6% so in real terms it never changed.
As a result we have loads of old labels saying 240 volt and when it goes to three phase we see 440 volt (not sure when it was 440) 415 volt and 400 volt.
It all should be 230 volt single phase, 400 volt three phase, and 460 volt split phase. We also have reduced low voltage of 110 volt which is either 55 - 0 - 55 or 63 - 0 - 63 if from a three phase transformer.
We get grey imports from USA and it does cause many problems. Hence interest in your system. The frequency is the main problem we use 50 Hz where you use 60 Hz but there has been a load of generators imported and if your on 120 volt the slowing motor will likely drop volts and frequency together.
Old 05-04-15, 04:23 AM
chandler's Avatar
Ericmark, the OP had a problem of not supplying the correct voltage to the compressor. Our system of 240 volts requires no neutral, but the 120 volts does.
Old 05-06-15, 10:44 AM
E
Thank you seems your 240 is like our 110 split phase.
