Romex pulled too tight through joist/subfloor?
Old 05-04-15, 10:42 AM
B
Hey. It's me again with another question on my new construction home.
Our electrical panel is in the basement. It's on a non-load bearing wall. When the HVAC guys did their rough in, they chopped it to run their ducts. The framers didn't have a chance to fix it before the electricians came through and tightened down all their cabling.
The framers came back and fixed it, although the end result is the cabling is pretty tight through through the floor joists and subfloor.
I'm just wondering how tight is too tight. Floor boards deflect a little bit and I don't want it to eventually rub off the sheathing and cause an issue.
Here are some pictures. The close up shows that one had the sheathing cut, but the paper is in tact and I don't think the insulation is damaged.
The romex shown is pretty tight running through the joist.
I actually cut out a little webbing for the white romex on the left...it was VERY tight. You can see the cut in the sheathing on one of the 12/2 lines.
My main power line also has some twist in it, but I imagine that's ok?
Old 05-04-15, 11:44 AM
ray2047's Avatar
I'm wondering about the bundling and lack of fasteners for the cables but not a pro. One should answer your post soon..
Old 05-04-15, 11:45 AM
Received 3,423 Upvotes on 3,069 Posts
The service cable comes twisted so that's ok. I'd highly recommend installing nail plates where I put the red X's to protect the wiring from nails. Anywhere where you'll be rocking and there is a possibility of a nail/screw hitting a wire.
You may need to install horizontal pieces of wood so that the wiring to the panel can be fastened.
Old 05-04-15, 06:09 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
For support I think I'd install a few Colorado Jims. They are quick and easy.
https://www.erico.com/catalog/catego...=en&country=US
OR...... a few 3M Cable Stackers. Also quick and easy.
3M Cable Stacker - White 25-Pack (Case of 10)-SI-1 - The Home Depot
Old 05-04-15, 06:11 PM
What about the service cable Joe ?
Old 05-04-15, 06:31 PM
Tolyn Ironhand's Avatar
Received 676 Upvotes on 573 Posts
I would just install a flat 2x4 between the studs, flush to the back side, and install NM staples to "debundle" the cables. Install nail plates over any hole less then 1 1/4" away from the nailing face of the framing members.
Old 05-04-15, 06:41 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
I too would use 3M Stackers and cut those bundles loose.
Old 05-04-15, 06:44 PM
Received 125 Upvotes on 110 Posts
I'd be far more concered with the lack of naiilers for the sheet rock
Old 05-04-15, 06:48 PM
CasualJoe's Avatar
I'd leave it alone unless the inspector made me do something with it.
Old 05-04-15, 06:57 PM
pcboss's Avatar
SER cable has a natural twist.
Old 05-04-15, 07:11 PM
You missed my point completely. Did you read my post (#3) where I mentioned installing horizontal strips of wood to fasten the wiring too. Then you said use stackers. How do you fasten the service cable to a stacker ??
I know service cable has a twist ... cmon guys.
Old 05-04-15, 07:29 PM
pcboss's Avatar
The OP was concerned about twist in post #1.
Old 05-04-15, 08:51 PM
B
Thanks for the responses.
We actually have been living here for about 2 weeks - so all inspections are done and (obviously) a C of O issued.
My biggest concern was with how tight the white/yellow romex was against the floor joists and subfloor. Given the number of comments, it seems a bigger issue is the lack of strapping for the loose cables. That's an easy fix and one I can take care of.
