need to make battery packs for lights
Old 05-07-15, 12:11 PM
C
if have these little lamps:
they have regular 2 pronged ac plugs for the wall. inside the can is a regular E-27 socket for a bulb. supposedly they're 60W max.
i put these bulbs in them:
it's an LED bulb that changes colors from a remote controller. input voltage is 85V~265V AC 50-60Hz. uses at most 9W.
i want to make battery pack to power one of these lamps with this bulb in it. i don't want to modify the lamp; i want to be able to just plug it into the pack. the power needs to last like 6hrs at a time.
what type of battery pack do i need to make?
Old 05-07-15, 12:24 PM
ray2047's Avatar
You would need to use a large battery such as a car battery and an inverter. If you used to series wired sets of 60 D cell batteries in parallel you would probably get only a few minuets of use.
Old 05-07-15, 12:28 PM
Tolyn Ironhand's Avatar
Received 878 Upvotes on 741 Posts
Yeah, that type of lamp is not a good option for what you want to use it for being it is for AC volts. Look for a different lamp with uses 12 volts DC, they will be easy to find.
Old 05-07-15, 04:46 PM
C
the lamp is pretty simple. i'm most interested in keeping the fixture body because of the look. i guess i'm fine with changing the electrical components of the fixture, of which there hardly is anythig. electrically it's pretty much just wires and a socket.
so i've seen those battery powered sockets you can put any e-27 bulb into and just stick it wherever. those take like 4 AA batteries. supposedly i can stick my LED bulb right in there and it works. can i not just re-wire the lamp for how many ever batteries i need?
Old 05-07-15, 05:51 PM
The issue is not the fixture but the LED bulb. The bulb you picked out is input voltage of 85V~265Volts AC 50-60Hz. 1 AA battery voltage is 1.5 volts DC. These voltages are miles apart and are not the same thing. The only practical way to do it would be, as Ray posted, use a car battery and an inverter to change 12V DC to 120 volts AC.
