Changing Motor Voltage
Old 05-07-15, 02:00 PM
B
Camping on: I have an old AC motor with good bearings...still have fan blades attached. Is there a way to change to 110 so I could build a box around it and use it for a "barn or garage fan?" Barn doesn't have 220v. Has three non-descript wires (brown, orange, and ???) Thx.
Old 05-07-15, 02:49 PM
Received 3,884 Upvotes on 3,481 Posts
Is there also a terminal block inside the wiring area ?
Is there any info on the motor or inside the motor cover ?
If not...we'll need the color of every wire you can see.
Old 05-07-15, 07:19 PM
B
More infor. Rudd unit. Brown black and orange 1.3 amp hp1/5 rpm1075 Emerson k55hxjkl-2918 part number 51-21854-02. No terminal block on outside. Wires go righ in. Thanks for the help
Old 05-07-15, 08:24 PM
I recognize the part number. That is a motor for an A/C condensor fan. It is dedicated for 240vac use only. No conversion possible.
