Help with exhaust cutout switch
Received 0 Votes
Hi everyone,
Have an issue with my exhaust cutout.
I will try and explain my crude paint wiring diagram as best I can.
Left: How my exhaust cutout was wired. Could open or close with a remote. Something in the control box malfunctioned, and it started melting (worked for almost a year)
Middle: (Control box gone) wires straight, will open the cut out
Right: (Control box gone) wires crossed, will close the cutout
Any one know how to wire this up to work again, maybe with a relay and a 3way switch? I obviously don't want to swap the wires every time I want to open and close.
I'm have a basic understanding of electricity, but I just can't seem to find the simple info on things like DPDT 3 way switches to wire it correctly. Thanks for any help everyone!
What you need is a DPDT toggle switch. This is a double pole, double throw switch. It allows for 2 different inputs and one output (the DP side) for each of two switches (thats the DT) - even though it looks like and toggles like a single switch. This means each side has two inputs and one output. You would cross wire it so the inputs are reversed when you toggle it.
Try doing a web search for "Wire a DPDT switch for reverse polarity" to see how it is wired. very straightforward.
- Peter
- Peter
You need to determine if the cutout requires constant power to stay open and constant power to stay closed.
You will need a DPDT center off switch if the cutout doesn't require continuous power.
OR
You will need a DPDT switch if cutout requires continuous power.
Either way.... you probably will need to use an ignition source for your power so it goes off with the key.
OR
Received 0 Votes
The cut out does not require constant power. Only about 1 second, and it opens, or closes.
I will look into what you all have posted here. I appreciate the help, think i need one with DPDT with center off switch
You can also get a DPDT center off momentary contact. That means the switch stays in the middle and you tap it up or down.
Amazon has a few choices. The one for $4 with the red on on plate would work fine. There are also rockers there you could use. The on/on plate doesn't have to be used.
Amazon DPDT switches
Detailed switch from Amazon
This is just one source. There are many.
Received 0 Votes
Got the switch
Hey all I got the DPDT on/off/on momentary switch (RadioShack has them btw)
It has numbers going counter-clockwise 1-6.
Can you draw me up another diagram?
I would like to use a 12V+ ignition power source, and a new ground.
As I mentioned before I need the up position to open the cutout, and the down position to close it. Thanks for any help everyone! I appreciate it.
