DC Inverter
Received 0 Votes
DC Inverter
I am interested to know how large of an inverter (DC to AC) would be recommended for a 10 AMP ac initial surge and 6 AMP run. The 6 AMP run would be for about two to three minutes, once maybe twice a day at different intervals. Would a 1K watt suffice or should I go larger? I am planning to use a heavy duty battery pack or 12vdc battery to run the inverter. My application is running a vacumn cleaner motor that pumps air into a tank to raise a boat lift. I measured amps with a UEI meter. Thanks
At 10 amps your surge is 1200 watts. The surge or peak of the inverter should be at least that. I would recommend going a little higher (1500-2000w peak) as it seams that some manufactures overstate their products specs.
Is this a shop vac motor? 6 amps seams a little light if it is.
Received 0 Votes
OK, I will go a little higher, will shop for a 1500 and preferably 2000. Yes, common application with many lifts is a fairly large tank and a vacuum cleaner motor that simply pumps air. Thanks folks, appreciate the replies
That's extremely interesting. Vacuum cleaner motors are known for their sucking power.... they are not known for their blowing power.
I recall wiring a truck dock leveler that was air powered rather then spring or hydraulic. Sounded just like a vacuum and worked quite well.
