Wiring my homemade bed and headboard
Old 05-10-15, 11:35 AM
B
Lightbulb Wiring my homemade bed and headboard
The only electrical background I have is replacing light fixtures and simple receptacles. Carpentry is the only thing I'm halfway decent at. I'm trying to add some lights and outlets to this bed I've made. My intent is to run everything to the wall receptacle(15amp). Here's what I WANT to do. (See photos)
An "INDEPENDENT"(to me, meaning it has a switch that doesn't affect the other light or anything else) overhead light on each side of the headboard. With an "independent" rope light under each side of the bed. Also a receptacle on each side for our phones/alarm clock or whatever. I haven't bought anything yet until I know what the best way to do all of this is or if its even possible. Again, my knowledge is very limited and I don't now all the terminology, or what gauge/type of wire to use etc. But any help would be greatly appreciated. Thanks!
Old 05-10-15, 11:57 AM
Received 2,951 Votes on 2,663 Posts
Welcome to the forums.
Thanks Ben. I put the picture back in your original post.
Your diagram looks good Ray.
Old 05-10-15, 12:11 PM
ray2047's Avatar
Received 15 Votes on 13 Posts
I have annotated your diagram to show one way to do it. PJ may have a better way so I will wait for his comments.
The receptacles on either side of the bed would have one switched plug in for the rope lights and one always hot plugin for other things.
At the existing receptacle you would need to replace it with a deep old work box. All wire in the box would be connected to pigtails and the pigtails to the existing receptacle.
Old 05-10-15, 01:11 PM
chandler's Avatar
Received 9 Votes on 8 Posts
Just guessing, but I think the OP wanted the canopy, or bed light to be on three way switching. Hey, Ray, just a few more lines Good job.
Old 05-10-15, 01:16 PM
ray2047's Avatar
Now you say that Larry after I drew this. We will wait to see if he wants 3-ways for the rope light. Ben, if you do want a single rope light on a 3-way it will be easier to use two individual switches on each side rather than the duplex you show. You really need the room of a two gang box for wiring and that kind of duplex combo is very expensive if you can find it. If it is a single rope light where were you going to plug it in?
Old 05-10-15, 02:14 PM
B
Thanks Ray, I may be in way over my head but I think I can figure this out from the info you've given. The rope lights do not need to be on a 3 way. I actually bought two separate rope lights(one for each side thinking they would also have their own independently controlled switch). I just want what ever would be simplest for me to wire, while still allowing the overhead lights to each have their own controlled switch. Just thinking of the future, would it be possible to make this all capable of just plugging into the wall so it would be easy to move? Just curious. I may still have a lot of "googling" of terminology to do but these diagrams should really help me. Thanks
Old 05-10-15, 03:05 PM
ray2047's Avatar
The way I drew it would be simplest. Any questions just ask. The two sides are wired the same so I only drew one side.
Old 05-10-15, 03:12 PM
ray2047's Avatar
It's possible but with out UL approval your AHJ and/or insurance company might not approve of it.
Old 06-02-15, 06:29 PM
B
Well my wife and I finally agreed on what lights to put on the headboard. I've wired one side completely and The bottom switch is controlling the headboard light and both outlets receptacles are continuously hot. One is not affected by the other switch. Any thoughts as to where I went wrong?
Old 06-02-15, 06:37 PM
ray2047's Avatar
Did you remove the tab on the brass side of the receptacle.
Old 06-03-15, 02:41 PM
B
Yes, I broke the tab on the side with the black and red wire.
Old 06-03-15, 02:50 PM
ray2047's Avatar
Are you sure the red and black wires are on the side of the switch with no tab? Post pictures of both sides of the switch with wires connected.
Old 06-03-15, 03:03 PM
B
right side of the outlet black and red
Old 06-03-15, 03:06 PM
B
Attachment 51487 left side of the outlet white
Old 06-03-15, 03:45 PM
ray2047's Avatar
But I asked about the switch not the receptacle.
Old 06-03-15, 03:51 PM
B
Should the tab on the switch(same side) be broken as well?
Old 06-03-15, 04:33 PM
B
I just undid the wiring on the switch and flipped it 180 degrees and wired it back up so this top switch appropriately switches the top light. I think I had it upside down. Both plug ins are still both hot so I'm going to switch the black and red wire on the plug and hopefully I won't blow up
Old 06-03-15, 04:51 PM
B
All is GOOD Ray! The only thing I did different from your diagram was switch the black and red wires on the outlet. The double switch must have been "upside-down." I based right side up on the brand being readable upright. But everything seems to be good. I'll wire the other side and when the beds all done I'll post a short vid of everything working.
Old 06-03-15, 05:46 PM
ray2047's Avatar
Good, thanks for letting us know. Now you know duplex switches have no up or down. You connect based on the tab or a marked common screw (usually dark gray).
