Designing a surface mount parts power supply
Received 0 Votes
hai every body, i need to construct an AC to DC converter.if possible without using a transformer.
here my input will be 220-250v 0.3amp AC
required outputs a) 12v 2amp 24w DC b) 12v 5amp 60W
if not possible without transformer circuit
Received 0 Votes
Moved from: http://www.doityourself.com/forum/li...ing-ideas.html
i too need the answer for the same , is there any method to get 12vdc apart from using a transformer. i mean in a cost effective way
There is always a transformer. Even in a switching supply there is a transformer.... just smaller.
I wouldn't attempt to build a switching power supply based on the cost to buy one.
You need 12vdc at 2A and 12vac at 5A ?
One of the benefits of a transformer is safety, it isolates the ground between the circuit and the power source. Where what you are asking can be done, if you provide a bit more input power, as PJ says, why reinvent the wheel, there are already inexpensive boxes out there doing this.
Is there a reason you want or need to address this at the component level? What's your project?
Bud
Bud
A transformer changes voltage levels in an AC circuit, which you need.
A rectifier then converts AC to DC, which you need.
Various other components smooth and condition the power so as to not damage the load components, which you probably need.
A DC power supply combines all of these functions. They are widely available and cheaper than the components it would take to make one.
Received 0 Votes
thank you pete ,bud ,ben .thanks for your reply.
the post is put by myself, actually i couldnt login coz i have no access to my mailID,i signed up previously using facebook,i have lost that mail ID. so please excuse
yes Mr.pete , i need to construct two devices to give outputs 12vdc at 2A and 12vac at 5A corespondingly.
Bud, would be grateful for a component level detailing.project is power source for LED strips.
Mr.Ben, i need to make it in bulk quantity and and i should ensure the safety of the load components.
could you guys please help me.
You need to explain what you are doing. What is the project. You mentioned LED lighting.... is this for LED power ?
Many times a power supply is not incorporated IN a project but is kept separate.
If this is something your are planning to do in bulk quantities then you need to work directly with an engineering firm to have the power supply design to be compatible with the project as it sounds like you want to be using the same pc board.
