broken cartridge fuse stuck.
I purchased a Tent trailer and found a blown cartridge fuse that runs the fridge. Its broken in half and stuck inside. Any tips for getting it out. I think its stuck inside whats called a "Panel Mounted Fuse Holder". Any tips would be appreciated.
Welcome to the forums.
This is a panel mounted fuseholder. The cap comes off and the fuse is spring loaded and should come out. If it's broken or stuck then you may have to replace the fuseholder. Sometimes you can use a thin pair of needlenose pliers to help the fuse out.
