Recessed lighting issue
Hello all,
I'm a new home owner and I'm finishing my basement and I've wired a new 15 amp circuit with an outlet and 4 recessed lights.. I turned on the power and everything works except the lights.. I tested to see if there was power going to the cans and there is to all four. I tested the outlet that is before the light switch loop and it works as well. I looked at all the wiring and everything adds up.. I'm confused, please help.. Some context I live in RI and the basement is all new construction.
Welcome to the forums.
The receptacle works well but the lights don't work at all. This would be a perfect place to have a voltmeter to check for 120vac.
Do you have a meter..... not a non contact test pen ?
Temporarily Suspended
Recessed lighting won't work in RI. You either have to change the lights to LED or move. JK
There could be a lost neutral somewhere. Check your junction boxes.
Checked all Junction boxes and all connectors are tight.. I'm not sure how reliable the non contact pen but when the switch is on its have power to all cans but none of the bulbs are lite
The neutral is the white wire. It's possible that it's not making a complete connection somewhere along the line. Between the breaker box & the lights, how many junction boxes are there? Look in the breaker box as well for a bad connection.
From the breaker box there is one outlet and the light switch itself, I tested the outlet and it worked fine and the switch works as it should. Would the user of an AFCI breaker be the cause?
You didn't say how you delivered power to the lights.
Does the wiring go like this:
- black and white from receptacle into switch box
- black from receptacle to one switch terminal, white from receptacle tied to white to lights with wire nut
- black to lights attached to other switch terminal
If so, this is correct. You will have to open up each light wiring box to ensure the wires were not over twisted. When connecting wires with nut, sometimes they can be pulled up into wire nut too far, causing a lost connection. Basically the insulation gets pulled up into connection.
Let's go back to the beginning. You opened the breaker box & you installed a 15 amp breaker. When you ran the Romex, where in the box did you connect the white wire & what was the next stop after the breaker box, on the white wire? Was in a junction box or the outlet?
OK.. From the breaker I ran Romex to an outlet(attaching to silver screw using a pigtail) from the outlet I ran to the switch (attaching the neutrals with a wire nut) then ran from switch to the lights.
I ran to the switch
So both the black & the white wires went to the outlet. Then a second white wire continued to the lights & a second black wire went to the switch. Then a 3rd black wire went to the lights. Is all that correct?
black and white went to switch then black and white went to lights
At the switch two blacks to the switch and the two whites connected only to each other.
#23
Correct ray, the two neutrals are connected only to each other with a wire nut and the hot from the outlet is connected to bottom terminal and the hot going to lights is connected to top terminal and the ground are connected together and attached to switch via pigtail with wire nut
