Dead GFI receptacle- other outlets on circuit fine
A bathroom receptacle suddenly stopped working. It was a GFCI, and resetting it did nothing. No other outlets seem to be affected, no breaker was thrown. I removed the GFCI and measured the voltages (Fluke 175).
With the breaker on:
Hot-GND: 5.6 V
Hot-Neu : 0.9 V
Neu-GND: 4.7 V
With the breaker off:
Hot-GND: 3.9 V
Hot-Neu : 0.6 V
Neu-GND: 3.3 V
Any ideas on what could be wrong/how to fix this?
Hot-GND: 5.6 V
Hot-Neu : 0.9 V
Neu-GND: 4.7 V
Hot-GND: 3.9 V
Hot-Neu : 0.6 V
Neu-GND: 3.3 V
Welcome to the forums.
Basically with those measurements you are lacking your 120vac hot line.
Did you have your meter set to AC voltage..... not DC voltage ?
You will need to determine what else is on that circuit. If the problem is not there then it is at the last working device before that one.
