Red Wire in Receptacle
Old 05-18-15, 10:04 PM
WRDIY's Avatar
Received 41 Upvotes on 39 Posts
Need help on this. I need to expand a current receptacle (on 20 amp circuit) to two in a gangbox. This is out in the garage and next to the washing machine, means that the receptacles need to be GFCI and Tamper to meet my city code.
I have changed receptacles before but usually with Black and White wires. This situation is two white wires and a red wire which I am not sure how to wire this. Do I treat the Red wire like the Black wire? Do I hook it up to the brass screw? Why is there two White wires and what am I supposed to do with the extra White wire?
These pictures show the current receptacle:
Size:  25.8 KBName:  20150518_183817.jpg
This is the new receptacle:
Old 05-18-15, 10:23 PM
E
Received 5 Upvotes on 5 Posts
Red is hot. Extra
White is probably going off towards another fixture
Mod Note: Reply does not make sense nor does the wiring given the information provided by the original poster.
Old 05-18-15, 10:29 PM
Handyone's Avatar
Are you changing out this single gang box to a two gang box with 2 receptacles or just wanting to swap out this single receptacle for a GFCI?
Old 05-18-15, 10:34 PM
WRDIY's Avatar
I am changing from single gangbox to two gangbox with two receptacles.
Old 05-18-15, 11:39 PM
Handyone's Avatar
I intended to answer your question, but it appears as though you have a multi-wire branch circuit (MWBC). It also looks like it was wired wrong, with the neutrals going to the receptacle rather than pigtailed.
Please wait for further input.
Old 05-19-15, 12:46 AM
ray2047's Avatar
Is this receptacle controlled by one or two breakers?
Is the receptacle controlled by a switch?
Please show us all the wires in the box.
Is this wired with cable or conduit?
Old 05-19-15, 02:08 AM
WRDIY's Avatar
Is this receptacle controlled by one or two breakers? One Breaker
Is the receptacle controlled by a switch? I don't believe so. Just the Washing machine and dryer.
Please show us all the wires in the box. The second picture?
Is this wired with cable or conduit? It is inside the wall. I will put a metal junction box on the wall and wire the new receptacles (GFCI).
Old 05-19-15, 05:25 AM
pcboss's Avatar
Received 196 Upvotes on 172 Posts
I suspect a MWBC using two single pole breakers. Looks like the blacks are spliced in the box.
Old 05-19-15, 05:39 AM
A
Received 279 Upvotes on 255 Posts
"Is this wired with cable or conduit?"
Can you use a flashlight and look into the back of the box and see whether there is a thin plastic or cloth jacket around the wires as they enter the box (cable wiring) or a closely fitting round metal jacket around the wires as they enter the box (flexible conduit) or a "pipe" or "pipe nipple" with loose fitting wires entering the box (rigid conduit) or the wires enter the box singly with no jacket (knob and tube wiring)?
If you are replacing the old plastic box with a new metal box, then screw in clamps are needed where the wires enter. The end of flexible conduit or a small amount of the jacket of cable must be visible just inside the box. The jacket or conduit may not end outside the box leaving a gap with the clamp coming down on the individual wires.
How many such clusters of wires enter the box?
What are the number and colors of wires in each incoming cluster?
To be absolutely correct, if black or other colored wires are connected directly to each other in the back of the box then the neutral white wires must also be connected directly to each other. Add a short length (pigtail) of the same color (here, white) to reach the receptacle from the new cluster of all white wires established in the box.
Caution: Do not unhook any wires without first labeling them and do not discard any old pieces or old components or the old receptacle until the project is finished and everything is working correctly.
Old 05-19-15, 06:48 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
It's cable. If you look carefully you can see the sheathing of one cable inside the box and it also has a bare ground.
Old 05-23-15, 01:28 AM
WRDIY's Avatar
Thank you to everyone. Weekend finally here and I will take the outlet apart and take a picture and post again tomorrow. Stay tune and thank you for the continue help.
