HVAC power wiring
Old 05-23-15, 09:28 PM
C
HVAC power wiring
Hello,first time posting on this site.Thanks in advance for all replies.
I'll start by explaining what i have done.I've replaced my heating unit with a new one from one side of the attick to the other and now i need to extend my power feed about 20 feet.The old unit was feed by a 2 gauge aluminum wire with a 90 amp breaker,but the new unit requires 2 feeds of 30 and 60 amps.What is the best way to extend the power feed?
Old 05-23-15, 10:08 PM
F
Welcome to the best DIY forum on the Internet.
There are several possible ways to extend the power, perhaps one of the best would be to use a power block connection mounted in a steel cabinet. This is one example. Others will have a more in-depth answer.
PB1042
I would use copper conductors with type THHN insulation, #6 for the 60 ampere and #10 for the thirty ampere. You need to run these conductors through conduit. Understand that you may NOT connect the copper and aluminum conductors directly to each other.
