Reload this Page >
Home sink disposal working on plug that acts weirdly to testers
Old 05-27-15, 04:51 PM
P
In-Sink-Erator disposal stopped under heavy usage. Reset button wouldn't immediately hold & unit was hot, so not surprised. Checked plug with "Snapit" circuit tester to be sure there was no power issue. Got no reading on tester (all 3 lights off). Tester label says that means "Open Hot." Checked, and no breakers tripped. Waited till unit cooled down and the reset button would hold. Then unit ran correctly again. Unplugged unit and plugged tester back in. Same reading (all 3 lights off). Tried tester on different plug and it displayed correctly (light 1 off, lights 2 & 3 green). Tried a different tester (A.W. Sperry Instruments) and got the same results (all 3 lights off on the plug where the disposal plugs in; light one off, lights 2 & 3 yellow). Yet, disposal works fine when connected to that same plug.
Could there be that the plug is incorrectly wired that makes it show "Open Hot" on 2 testers, but still provides electricity to make disposal run? I looked & there is a black wire plugged in at the top on one side, a white wire plugged in on the top on the opposite side, and a green wire screwed to the post at the bottom.
This seems weird.
Thanks,
Paul
Old 05-27-15, 04:55 PM
ray2047's Avatar
Those testers aren't allays accurate. A cheap analog (but not digital) multimeter is a better choice for testing.
Old 05-27-15, 05:02 PM
F
What kind of disposal do you have, a "batch" type where you stuff it full and then insert the stopper to turn it on or a "continuous feed" model where you have a separate switch that turns it on? If a continuous feed did you remember to turn the switch on when using your tester?
Old 05-27-15, 06:17 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
You may have a failing switch or a connection issue.
Old 05-27-15, 06:43 PM
JosiQDIY2015's Avatar
It may sounds funny and incredible, but yes a lot of people who tend to use those testers usually forget to turn on switches that supply power to some outlets before testing them. Therefore the tester will not turn a single light... but it was obvious that the outlet had electrical power before. That's why I always recommend that whenever a GFCI/Circuit Tester is used, a Non Contact Volt Detector should be also used at the same time to first confirm that the outlets are receiving actual electrical power at that precise moment... then proceed to test the outlets with the GFCI/circuit tester.
A Non Contact Volt Detector will help to remember the person that the switch that supply power to the outlet needs indeed to be turned on first.
Thanks.
Jos
