Breaker panel cover accident
Old 05-29-15, 04:39 AM
I almost had a bad accident when taking the cover off a panel.
Before I could get the last screw off the top left corner, the cover slipped from my hand and it swung sideway on that screw. I guess the divider that seperates the breakers on the cover slid across the top of the breakers and turned off about 5 of them.
Im pretty sure they didn't "trip" as they were just in the off position and only had to be switch to on. (Square D homeline).
I know you weren't here when it occurred, but do you think I caused any damage to the breakers that were switched off? Do you think the screw terminals could get loosened from what I describe? What kind of damage should I look for?
Old 05-29-15, 07:03 AM
pcboss's Avatar
Received 195 Upvotes on 171 Posts
I doubt that any damage occurred.
Old 05-29-15, 07:08 AM
Received 3,983 Upvotes on 3,575 Posts
I agree with the boss. If you had damaged the breaker(s) the handle(s) would have broken off.
Old 05-29-15, 07:13 AM
hey thanks...
that kind of what I was thinking... that a handle could have been broken or I wouldn't be able to reset the breaker(s).
It must not take much force to toggle those breakers or the cover must have really slid across them with force.
