Is Ground Wire To Pipe Okay?
Old 06-04-15, 08:25 AM
R
I would like to know if it is safe for optimum to install a grounded wire with a clamp around my electric pipe for my home.
Old 06-04-15, 08:49 AM
ray2047's Avatar
What is the ground wire for?
Old 06-04-15, 08:53 AM
pcboss's Avatar
Received 176 Upvotes on 154 Posts
Grounding conductors go to ground rods, metallic water lines and Ufer grounds, not electrical conduits.
Old 06-04-15, 04:39 PM
R
They installed cable service for my neighbor but used my electrical pipe to ground a wire with a clamp around the pipe.
Old 06-04-15, 04:54 PM
ray2047's Avatar
Are you in the same building? Do you share an electrical panel?
Old 06-04-15, 06:25 PM
F
Telephone and cable TV companies routinely "ground" their systems to a nearby electrical conduit. I don't know if this is entirely kosher with the National Electrical Code (I don't know that it isn't, either) but it is a common practice.
The requirements are in Article 800.40,B(1) and (2). in the 2002 NEC.
Old 06-05-15, 06:48 AM
I
Received 45 Upvotes on 43 Posts
If the metal conduit is part of the service entrance it is a legal ground for telecom, CATV, etc.
