need to put 1 pole 15 AMP circuit breaker in Crouse Hinds Panel
Hi,
I am new and if I posted in wrong question at wrong place, please forgive me.
When I bought my house, inspector mentioned me that there are 3 double tapped in our house panel and all three extra taps are for path light and very light load so I didn't do any at that time. Now I have to sell my house and I have to fix that for home inspection.
Panel box is 200A Crouse Hinds by Cooper industries with 2 lines (20 space for 1 line).
There are 8 more free space to use.
I need 3 15 A circuit to put in. But Home Depot has no Crouse Hinds anymore.
When I check on the internet it said Murray will be fitted in that box.
I just want to make sure it's ok to put in.
Please help me with your professional.
Thanks in Advance.
Thanks in Advance.
I believe it is correct you can use Murray breakers in Crouse Hinds panels.
You could also just wirenut a short pigtail wire onto the three lighting wires so only a single wire goes to the breaker. That will solve the triple tapped wire problem very cheaply.
Thanks a lot,
, I just worry about wrong breaker or may not look good for inspector and get repair order. At that time I will be in far, far away from this house.
