Electric for dishwaher
Mod note: Copied from anther thread. Unrelated text removed.
There is 110V AC outlet just on that wall [I can use for the dishwasher]. So, electrical may not be an issue (similar to fridge).
https://imgur.com/a/Iuvj7
There is 110V AC outlet just on that wall. So, electrical may not be an issue
That sounds complicated then. I think we have some fuses (glass fuses) un-used in the electric box. We do have dedicated circuit for fridge and stove in the kitchen. Is it simple to route to make a dedicated circuit?
Ease of running a new circuit depends on access and location of the fuse box. If you have unfinished space above or below it may be fairly easy. The bigger problem may be the fuse box. If it is 60 amps your service may be near over load. If it is 100 amp and you have all gas it may be okay but you usually can't add new separate circuits to a fuse box. Post a picture of the open fuse box.
If there is no unused Edison fuse holder in the box then you really need to consider replacing the breaker box with a new service. You also might be able to add a subpanel if you have an open 60 amp pull out fuse holder. Can you post a picture of the fuse box with the cover removed?
