The "COMMON" wire color? Replacing an old dimmer switch.
Received 0 Votes
Hey guys,
I am installing a new dimmer switch. I removed the old switch from the wall box and found 3 wires: Black, Red, and Green.
Now the new dimmer switch has me confused:
There is a screw for Ground (obviously the Green wire);
but then screws to attach "Single Pole" and another for "COMMON" (the "COMMON" screw is black).
Is "COMMON" my 'hot' Black wire? ...or the red?
Thanks! I'm in Massachusetts, USA.
Received 0 Votes
Actually, I should have been more specific: the instructions have 2 options.
For 'single pole' it instructs to attach 3 wires - 1 labeled "single pole" (Wire to Light), 1 labeled "COMMON" (Wire to Source), and Ground.
For '3-way- it instructs to attach 4 wires - 1 labeled "single pole" (traveler to 3way), 1 labeled "COMMON" (wire to source), 1 labeled "3-way" (traveler to 3way), and Ground.
I have 3 wires coming out of my wall only, Black, Red and Green so I assumed the "single-pole" option... but I just don't know which wires are which.
Thanks again.
Thanks again.
