MBR outlets not working
Received 0 Votes
Just had thunderstorm roll through, power went out. Power came back on and MBR and additional BR lights were not working. Went out to breaker box, these 2 breakers were tripped. Reset breakers. MBR outlets still not working (all 5 are not showing any juice). Checked all GFCI's inside and outside. Reset all breakers in box. MBR outlets still not working. Is it time to call an electrician or am I missing something? I am female and will not touch electrical in my house, just too scared of it. Just want to make sure there isn't something else I can check before I make the call to the electrician. Thanks for your help.
Received 0 Votes
Forgot info
Forgot to mention that the lights are back on in both bedrooms. It is just the 5 wall outlets that are not working now. They were fine prior to the storm. Not sure how the power company would be involved with only 5 breakers, can you please clarify? Thank you!
Probably you don't need to call the power company in that case. Have you read http://www.doityourself.com/forum/el...ther-info.html.
Received 0 Votes
Yes, I have been reading lots the past 3 hours. Unfortunately I have just now put in a call to an electrician. I don't think this is something I can fix. I appreciate your input.
Just reading through the thread and wanted to double check a couple of simple steps.
1. When you reset some breaker, you should flip in the off direction first and then back on.
2. You said you checked all GFI receptacles, but they can be hidden in strange locations and not necessarily in the room with the problem. Check the hall, behind the bed and furniture or, hate to say it, even the basement.
Good luck,
Bud
Good luck,
Bud
Received 0 Votes
Problem solved....and another found
Electrician came out today and found the problem. Said that one of the outlets had a neutral wiring (?) and that it is possible the outlets could have gone off at any time. Probably a coincidence that it occurred when the power went off.
On another note, when the electrician was taking off the cover to the breaker panel, he got an arcing. When he removed the panel, he found that the supply lines (two large lines coming in from outside meter box) had not been tucked properly and that the screws had penetrated the insulation of these lines. One screw had gone all the way through. Said it could have happened when house was built or possibly when home inspector did our inspection. Needless to say, I am glad that I haven't had anything bad happen due to that situation and he is giving me a quote for repairs.
Thanks for all of your assistance the other night. It's nice to know there are forums around to help out us little old ladies.
