Small Nick in Neutral Wire Insulation
I was wondering if someone could help me. I was in the process of replacing a smoke/carbon monoxide detector, and I noticed that there is a very small nick in the neutral insulation. It does not appear to be deep, as I cannot see the copper wire. Is there anything that I can do? I wasn't sure if I should leave it alone, tape it, or use some other means. I'm not familiar with the NEC requirements for this type of issue. I've included a picture below. It's on the left side of the wire (near the top). I appreciate any assistance.
Welcome to the forums. Place heat shrink tubing on the neutral wire for an inch or so, shrink it in place. They are called wire strippers, not gouging pliers
Using the proper tools help eliminate problems like this. Looks as if your hot wire took a light hit, too.
Thanks. The hot wire is actually in good condition. It may be paint that you are seeing in the picture. I'm not sure how the nick got on the neutral insulation. I'm assuming that it was already there. I didn't even touch that area. Can I get something like this at Home Depot or Lowes?
Heat shrink is fairly readily available.
Before shrinking I would check the integrity of the conductors. That black looks pretty bad. I would bet they used a razor knife to slit the sheath.
