Mini Split wiring question
Old 06-14-15, 09:08 PM
T
My mini split wire tag is attached.
I was thinking 10 gauge romex with a 30 amp breaker to an outdoor disconnect. Is this correct?
If so, do I need a certain type of disconnect? fused, breaker, switch etc?
The unit came packaged with a 6ft length of 16gauge stranded with a hot neut grnd colors so I guess thats to power from the disconnect to the outdoor unit.
Seems small for 17 amps.
Please let me know if you need more info
Edit: I will run romex from my basement subpanel outside in conduit to the disconnect.
Old 06-14-15, 09:58 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Romex is not rated for use in conduit outside.
30 or 60 amp unfused disconnect.
Fixture wire is not rated in the same way as "house" wire. rating is based on insulation temperature rating and specific use.
Old 06-15-15, 05:16 AM
pcboss's Avatar
Received 85 Votes on 73 Posts
You can use #12 to feed the unit. As Ray already said, do not use NM. You could use UF cable or individual conductors in conduit.
Old 06-15-15, 08:51 AM
T
Ok Thanks for the replies.
So is this the right combo?
30 Amp breaker
12/2 UF
30 or 60 amp unfused disconnect. Any thing wrong with fused? Just curious
Will this work?
Shop Eaton 30-Amp Fusible Metallic Disconnect at Lowes.com
Does the control wire from the indoor unit to the outdoor unit need to be in flexible conduit?
Old 06-15-15, 09:04 AM
pcboss's Avatar
There is no need for fuses. They are not needed and you would need to keep spares if they would to blow or not have A/C. They should not blow, but could. The fusible is probably more expensive than the pullout disconnect also.
Old 06-16-15, 07:08 AM
CasualJoe's Avatar
Received 85 Votes on 75 Posts
A non-fusible disconnect would be less than half the cost of the fusible disconnect you selected when you factor in the cost of fuses.
Shop Eaton 60-Amp Non-Fusible Metallic Disconnect at Lowes.com
Old 06-16-15, 08:47 AM
pcboss's Avatar
I think the last pullout i bought was like $6.
Old 06-18-15, 08:45 AM
T
Thank you all for the replies and help
Old 06-21-15, 05:14 AM
A
Received 14 Votes on 14 Posts
30 Amp breaker
12/2 UF
Will this work?
#12 on a 30amp breaker? Should this not be #10 on a 30amp breaker?
Old 06-21-15, 05:36 AM
pcboss's Avatar
#12 is fine. Your load is 17 amps. The breaker is to allow the unit to start. The conductors are sized to the run load.
Old 06-21-15, 05:41 AM
A
Thank you for that info. Nice to know. But could #10 still be used without problem?
Old 06-21-15, 05:50 AM
pcboss's Avatar
You can use larger if you like, but there is no need to.
Old 06-21-15, 06:01 AM
A
Thanks, nice to know for the future.
Old 06-21-15, 05:55 PM
CasualJoe's Avatar
PCboss is correct. The rules are different when a motor is involved and that's all the compressor load is, a motor.
Look again at the unit data plate, it says "Max. Fuse - 30 amps". Some inspectors will go so far as to require a fusible disconnect with 30 amp fuses in a case like this, but if the plate says "MOCP - 30 amps", either a 30 amp fuse or 30 amp circuit breaker will be sufficient.
Old 06-22-15, 01:24 AM
A
Thanks for the info CasualJoe; will keep it in mind. If using a fused disconnect would it be best to use slow blow fuses in this case or not needed because of the size requirement of the 30amp fuse which is taking into consideration the up-surge of the initial starting of the motor load?
Old 06-22-15, 09:04 AM
ray2047's Avatar
A/Cs should always be on slow blow but you do not need to use fuses so just don't.
Old 06-22-15, 11:12 AM
CasualJoe's Avatar
Unless the AHJ requires a fused disconnect, I'd never use one. A non-fusible 60A disconnect only costs around $6. If using fuses, yes, always use the time delay type fuses for a motor load.
Old 06-22-15, 01:12 PM
A
Thanks CasualJoe and ray2047.
