3 hp relay question
Old 06-18-15, 02:37 AM
A
3 hp relay question
Hi
i got 3 hp motor start capacitor
voltage 220 volt
1440 rpm
what is the typical relay switch for it
Old 06-18-15, 08:41 PM
Tolyn Ironhand's Avatar
Received 860 Upvotes on 723 Posts
What is the current draw? Single phase or 3 phase? What do you plan to control the relay with? Perhaps a better description of what you are doing will give us better incite to provide answers.
Old 06-19-15, 07:31 AM
A
thanks for your kindly reply
its single phase
the motor had a relay that convert the movement from primary winding to secondary ifter it reaches 90 from the max speed
i want to use this motor to drive a water pump
Old 06-19-15, 10:23 AM
A
draw current
i think 11 ampere
Old 06-19-15, 03:03 PM
I'm not sure I'm following, Are you talking about the centrifugal switch to drop out the start winding? What does the old "relay" look like? Is it inside the motor?
Old 06-19-15, 11:36 PM
A
sorry for my broken english
there was something look like 2 dishes to disconnect the start winding
after the motor reaches the max speed
but without it now
i must do that manually
Old 06-20-15, 12:06 AM
Received 3,880 Upvotes on 3,477 Posts
Can you post a picture or two for us ? http://www.doityourself.com/forum/el...rt-images.html
