40 AMP hot tub install
Old 06-18-15, 03:15 PM
C
Installing an older 40 amp hot tub at my house. I have the 40 amp GFCI breaker already. This tub does not use the neutral wire, just red/black/ground.
I haven't bought the wire yet but would like some room for upgrades later if not too expensive. So thinking still getting 3 conductors and maybe 6 AWG instead of 8??
My run will be 25 feet through a basement unfinished ceiling, then into an existing (and empty) PVC conduit for 20 feet (still inside), then outside under a deck for another 10 feet.
I can extend conduit outside under deck to tub or just staple to under deck joist or whatever.
Recommendations please?
Thanks!
Old 06-18-15, 03:54 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
You'll still need a disconnect within sight of the hot tub. Definitely run the 4th wire as whatever you replace it with may have electronics that will require a neutral. You can run the 6 if you feel you may upgrade the tub later on. Run THHN in conduit all the way. It looks more professional and you, by code, must protect the wiring.
Old 06-18-15, 04:24 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
The ground must be insulated on the exterior portion of the circuit if there is only a disconnect outside. If there is a breaker in the spa panel the ground needs to be insulated the entire run. There are also other conditions that must be met.
Old 06-18-15, 05:05 PM
C
Something like this is required?
GE 60-Amp 240-Volt Non-Fuse Metallic AC Disconnect-TFN60RCP - The Home Depot
I read somewhere that the 6 gauge would also be better to offset voltage loss over the run? Not sure if it worth it or not because it is a lot more expensive than the 8.
Old 06-18-15, 05:31 PM
chandler's Avatar
I wouldn't worry about the length until it approaches 100'. Increase it if you see your future needs may change, but not for voltage drop. And, yes this disconnect is fine.
Old 06-19-15, 09:46 AM
C
NMD90 - using the PVC conduit outside would be good?
Old 06-19-15, 10:59 AM
pcboss's Avatar
Not under the NEC rules. The ground is not insulated nor is it for use outside. I would suspect the CEC is similar.
Old 06-19-15, 11:21 AM
I
Received 45 Upvotes on 43 Posts
NMD cable is not for outside use. You would need at least NMWU, but I'm pretty sure even that is not allowed for a hot tub due to an uninsulated ground. TECK cable is common for hot tub connections in Canada.
Old 06-19-15, 11:22 AM
C
NMD90 inside then junction box to NMWU outside directly to the tub?
Old 06-19-15, 11:25 AM
I
No, I don't think NMWU is allowed. TECK if it has an insulated ground is allowed.
