Dryer receptacles
Dryer receptacles
After reading a bunch of threads and not finding an answer, does anyone have a simple answer for this?: What is the difference between the flush mount and surface mount electric dryer receptacles? I went to pick up a few things as I get further along with an addition, and there were two different 4-wire 30A dryer receptacles. Can't figure out which would be better. I guess I lean towards the flush-mount, but then what type of electrical box is needed? The receptacle seemed too big for a normal single-gang type box. What does the faceplate look like? Does the box get installed off the floor a certain distance? Does it matter? Thank you if you can help.
Surface mount receptacles come as a self-contained unit and can be installed without the need for a separate junction box. Flush mount receptacles have to be installed in a junction box, usually an extra-deep 4" square box with a double gang raised ring.
Code does not require a specific distance off the floor, but when installing consider locations that would be possible vs. impossible to reach with the dryer sitting there. Something like 24-30" off the floor you can reach over top of the dryer.
[ATTACH=CONFIG]52426[/ATTACH]
This box maybe a better choice if this is new construction,use a 2 gang plaster ring with it.
2-1/8" Deep, 4" Square Box with a Flat Vertical Bracket and (9) 1/2" Side Knockouts and (5) 1/2” Bottom Knockouts
Geo
Geo
Either in wall or surface mount, go with a 4 11/16" box.
Leviton | 30 Amp Dryer Receptacle | Home Depot Canada
IBERVILLE | Sq. Range/Dryer Box 2-1/8 In. Deep KO | Home Depot Canada
