Hot wire and neutral wire both are hot
Old 07-10-15, 06:49 AM
T
I cut out a short 2' long electrical cable that I bought from Home Depot. I insert only the black wire into an outlet, using my voltage tester I see all black, neutral and ground wire have voltage. Is it normal? How could I get voltage on the neutral and ground wire when they are not even connected to the electrical source?
Old 07-10-15, 06:56 AM
P
What kind of tester are you using? If it is a non contact tester, they are designed to test for an electrical field within a general area. Therefore if you get it close enough to the outlet it will light up regardless of which wire you think you are testing.
And what are you "testing" for btw....
Old 07-10-15, 06:57 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Why are you doing something so dangerous? How are you neasuring voltage? What instrument are you using? Why are you checking anyway?
Old 07-10-15, 09:49 AM
ray2047's Avatar
What is your meaning of "hot". A 120 volt circuit consists of two "hot" wires. The grounded conductor (neutral) and the ungrounded conductor. Electric enters via the ungrounded conductor and leaves by the grounded conductor. then it shifts direction and enters by the grounded conductor and leaves by the ungrounded conductor. It shifts in direction sixty times every second.
I suspect you were fooled by the misleading information on a non contact tester which suggests it is for finding voltage. It isn't really. It is for finding a magnetic field which may or may not indicate the presence of a significant voltage capable of doing harm.
Old 07-10-15, 07:12 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
The cable you bought from Home Depot should't have any voltage on it till it is properly connected to a live crcuit, note I said properly connected. You shouldn't be inserting any wires into a live receptacle.
