Reload this Page >
Light & Outlet go off after 15 mins of another light being on
Old 07-13-15, 09:26 AM
Mixdplate's Avatar
I have a light (Light 1) fixture that has the feed coming into it. On the same switch is another light (Light 2). An outlet in another room gets it's power from Light 1 and powers a separate switch light (Light 3) in the room with the outlet. If light 3 is on, outlet & light are fine. If Light 1 & Light 2 are on, Light 3 and the outlet will turn off after about 15 mins. A circuit test reads Open Neutral on the outlet. Attached is a diagram of the wiring.
Old 07-13-15, 10:32 AM
I
Received 45 Upvotes on 43 Posts
There is a loose connection, partially broken or corroded wire somewhere in this circuit. The likely location is in the light 1 junction box, but other junction boxes upstream of that box are possibilities too including the breaker box. The solution is to go box by box, remaking connections and replacing devices (switches and receptacles) until you find the bad one.
Please post back for additional instructions if you have aluminum wiring, a Zinsco brand or FPE brand electrical panel as you have found a symptom of a bigger problem.
Old 07-13-15, 10:48 AM
Mixdplate's Avatar
The feed is coming directly from the panel. All runs in diagram are the only things on that circuit. The wiring is fairly new. Checked all boxes every thing is connected tightly. I was thinking that the wiring in light 1 may not be correct.
Old 07-13-15, 10:59 AM
I
Are these recessed can lights with thermal cutout sensors?
Old 07-13-15, 11:01 AM
Mixdplate's Avatar
No. Just basic light base with bulbs.
Old 07-13-15, 11:09 AM
I
How long after the light goes out does it come back on? Do you have to do anything to get it back on?
Old 07-13-15, 11:29 AM
Mixdplate's Avatar
Light 2 and outlet will come back on after 5 mins or so as long as Light 1 is not on. If light 1 is on, I will have to shut it off and wait a few minutes before light 2 will work again.
Old 07-13-15, 12:24 PM
ray2047's Avatar
Are any of the connections back stabbed instead of on the screws?
Old 07-13-15, 12:47 PM
Mixdplate's Avatar
No, they are all on screws.
Old 07-13-15, 12:51 PM
I
If all the connections are tight, devices are good and it's all relatively new gear, I would start looking for a damaged cable. It is possible it was crimped or pinched during install, too-tight box clamp, rodent damage, puncture by picture-hanging nail something like that. One diagnostic test that might be revealing is to unhook each cable segment and measure the round-trip resistance, looking for anything that shows up as high. Wiggle everything around, pull on the cables a little. See if you can induce a failure to determine where the problem lies.
Old 07-13-15, 01:21 PM
Mixdplate's Avatar
OK. Was hoping that it may have just been wired wrong, and I can quick fix it. Looks like I will have to call the electrician back, as I don't have those sort of tools or know how to use them. He will find something wrong to charge me for.
Thanks for your help.
Old 07-13-15, 02:01 PM
ray2047's Avatar
Please let us know what the electrician finds.
