Cutting relief for outlet in brick wall
Old 07-14-15, 08:36 AM
K
Greetings. I'm in the middle of a kitchen redo and found that my exterior walls have no studs or hollow space where I can insert an outlet box due to a brick wall. There are several outlet boxes but it appears they have been chiseled out in order to insert the electrical box (see picture). Wondering if it is ok to do this in two more spots to run electrical to a garbage disposal and one to the microwave. Name:  kitchen q.jpg
Old 07-14-15, 08:40 AM
pcboss's Avatar
Received 196 Upvotes on 172 Posts
I would consider surface mounting the boxes.
Old 07-14-15, 08:12 PM
Received 3,994 Upvotes on 3,584 Posts
Is there just a single row of bricks to the outside of your house ?
You can chisel out the brick but you'll need to be careful when chiseling so as not to expose the box to the outside.
A house I worked in recently had two rows of brick. I was able to chisel out the inside brick leaving the outside one intact.
Old 07-15-15, 06:28 AM
Received 128 Upvotes on 113 Posts
Why not use a shallow box, they come in metal or plastic.
Carlon 1-Gang 17 cu. in. Shallow Old Work Box-B117RSWR - The Home Depot
