Whole house fan motor
Old 07-15-15, 09:09 AM
A
I'm trying to replace the motor to the whole house fan. The conduit wired to the old motor has red, white and black wires. The new motor came pretty wired with green, white and black. How do I rewire the new motor or connect the existing ones correctly?
Thank you
Old 07-15-15, 09:21 AM
ray2047's Avatar
What is the wiring at the timer.
Old 07-15-15, 09:29 AM
A
I don't understand your question.
Old 07-15-15, 09:36 AM
ray2047's Avatar
There should be a switch or timer controlling the fan. The wires you are looking at probably come from there. It will give us more info about the wiring.
Old 07-15-15, 10:34 AM
I
Received 45 Upvotes on 43 Posts
Is it metal conduit and did the old fan have a LO and HI setting?
Old 07-15-15, 11:23 AM
A
Yes it's metal conduit. It has a 3way toggle switch for high and low
Old 07-15-15, 11:38 AM
A
I've not yet looked at the internal workings of the switch yet.
Old 07-15-15, 12:30 PM
ray2047's Avatar
We don't need to know inside the switch just the wiring in the switch box.
Old 07-15-15, 07:30 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
The old motor was evidently a 2-speed motor for Low and High, but it sounds as if the new motor isn't a 2-speed motor. How did you come up with the information to purchase a new motor? Are you sure you have the right motor? You possibly just need a variable speed control instead of the 2-speed control, but more information on the old and new motors is needed.
