trying to dismantle motor for scrap
Old 07-15-15, 08:26 PM
supersonicklutz's Avatar
Its a motor from a washing machine. What is the best way to get it apart to liberate the wiring (and anything else of value) for scrap? Its about 7.5" from one end of the shaft to the other and about 4.5" across. I tried cutting through the plates that make up the bulk of the unit but stopped when progress was obviously very slow (photos 2 & 3). Im not sure what the metal the plates are made of, steel maybe?`Anyway, its worth more stripped down then whole. I wouldnt be doing this for just one, I have a bunch of them. Any suggestions?
I have more photos should that help.
Old 07-15-15, 08:37 PM
Received 4,082 Upvotes on 3,665 Posts
Quite a job putting them together. Even harder to take a part.
The bulk of the motor is laminated steel plates. You wont be cutting them easily.
What about cutting thru the coils of the copper wire and then pull the wire out ?
Old 07-15-15, 09:09 PM
XSleeper's Avatar
Received 1,957 Upvotes on 1,755 Posts
Did you try a grinder and 1/16" blade?
Old 07-15-15, 10:47 PM
PJmax, certainly sounds like an elegant solution. Are the plates worth wrestling with?
XSleeper, grind what?
Old 07-15-15, 11:06 PM
The plates are useless and won't come apart with major cutting.
Old 07-15-15, 11:07 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Personally, I think you'd make more going out and collecting aluminum cans, and get exercise at the same time. There's maybe a pound of copper in there, most of the weight is the steel. If they'll take it as is, use your time for something else.
Old 07-15-15, 11:23 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
here in NJ you get more more for a motor intact then you do for copper/iron. with motor as you show.....
If U look at the price difference after U separate it and labor spent you are losing....
Old 07-16-15, 12:10 AM
F
Received 39 Upvotes on 31 Posts
I did that a couple of times when I was in my teens; I had to cut each and every wire on each side and then pull it out with a pair of pliers.
Last week when I took some scrap metal to the recycler I got $1.50 a pound for the copper and $0.025 (two and a half cents) per pound for scrap steel.
Old 07-16-15, 06:50 AM
I
Received 45 Upvotes on 43 Posts
You could heat it to about 2000F and wait for the copper to drip out.
Maybe set it across the hollow of a cinderblock and sledgehammer the heck out of it? The big chunks will probably come apart.
Old 07-16-15, 07:24 AM
A
Received 287 Upvotes on 262 Posts
You cannot unwind the coils of copper wire without first disassembling the steel plates of the field assembly. It takes a lot of work to cut the copper coils and pull out one turn at a time compared with unwinding.
Some motors have copper coils in the armature. You may be able to unwind these if you figure out the correct order (unwind the coil that was wound on last).
Old 07-16-15, 09:00 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Scrap the whole motor as one unit,not worth the effort to strip the cu.
Geo
Old 07-16-15, 05:47 PM
Tolyn Ironhand's Avatar
Received 899 Upvotes on 760 Posts
I agree with Geo, Scrap it out as a whole.
Old 07-17-15, 10:09 PM
PJmax, that method worked quite well.
Not all the motors are the same so some got/will get stripped, other will be left whole. Once its all done, I'll report back on how I made out. Got 12 washers in the dumpster so far, got 8 more to go. Then theres lots of other ferrous and different non ferrous metals too.
