4 switches 1 light
4 switches 1 light
I have a situation where I need 1 light to be on 4 switches. I thought I did enough research and would get it right but I was wrong.
I have 14/3 wire ran for all the runs and I have this set up:
Power line from breaker panel - 3 way switch - 4 way switch - light - 4 way switch - 3 way switch. .. I found 1 diagram that showed this set up online and thought I could do it... but something is not right. The diagram does not really show how to wire the light very well, and I can't figure it out.
Welcome to the forums.
You cannot connect into the middle of a 4 way loop
Most common method:
Power ---- 3W ---- 4W ---- 4W ---- 4W ---- 3W ---- lights
Alternate method is to have lights and power at one end:
Power/lights ---- 3W ---- 4W ---- 4W ---- 4W ---- 3W
Most common method:
Run another cable, a 14-2, from the far 3 way switch back to the light box.
It is still possible that a box may be too small for all of the wires. Round or octagonal ceiling boxes are most likely to be too small and necessitate an extension ring (bottomless box).
