Closet light switch to code
Old 07-19-15, 08:58 PM
Exclamation Closet light switch to code
Hi,
We'd like to add a fluorescent strip light in a coat closet and instead of flipping a switch, want it to be "automatic" by using a normally closed contact switch in the door jamb (like a fridge). I know how to do this readily, but have no idea how to do it to code or if it's allowed at all.
Can anyone help?
Thanks guys.
Old 07-19-15, 09:34 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
They sell switches for that that meet code.
Source main image: smarthome.com
Old 07-20-15, 06:34 AM
Yup - that's it. Thanks Ray.
Question: What kind of cabling is run to it? NM-B?
Old 07-20-15, 07:59 AM
I
Received 44 Votes on 42 Posts
NM-B is by far the most common.
Old 07-20-15, 10:50 AM
pcboss's Avatar
Received 103 Votes on 89 Posts
You run a switch loop to the plunger. After installing one you will probably never want to install another one.
Old 07-20-15, 05:27 PM
I agree they are really a pain to run but they are very convenient. We have them in a couple of linen closets as well as a couple of small guest coat closets in our entry foyer.
Old 07-20-15, 05:54 PM
ray2047's Avatar
Or a low voltage magnetic switch and a relay.
Old 07-20-15, 06:17 PM
Certainly a viable solution but much more complicated and difficult for a DIY person to do in most cases.
Old 07-20-15, 06:40 PM
I put a motion detector in the closet - so when you open the door the light comes on.
Something like this:
Lutron Maestro 2 Amp Single-Pole Occupancy Sensing Switch - White-MS-OPS2H-WH - The Home Depot
Might be a bit easier to add a work box and fish a cable up the wall.
