Losing Outlets - Open Neutral
Old 07-24-15, 08:42 PM
I've been in my house 10 years. During a new flooring project, I moved the refrigerator (and everything else into the garage). The refrigerator worked fine for two weeks, then the outlet stopped working. I have an electrical tester and it said open neutral. The next week, the outside outlet stopped working, and it said open neutral. Then the bathroom outlets stopped working and all three say open neutral now. Most of the outlets that stopped working are GFCI. What could be going on and how to fix it? Yes, I tried resetting all of the outlets.
Old 07-24-15, 09:40 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Best practice is only one GFCI per circuit if down stream receptacles are fed from the load side of the GFCI. GFCIs fed by the load side of a previous GFCI can be problematic.
Or something else. They can be fooled. You need to use a multimeter, preferably analog.
