Is this wired correct?
Old 07-27-15, 10:50 AM
Single pole next to double pole light switch. Name:  image.jpg
Old 07-27-15, 10:55 AM
Received 1,186 Upvotes on 1,144 Posts
Sorry, going to need a lot more information. Can you fill in the details?
Old 07-27-15, 11:09 AM
ray2047's Avatar
Double pole switches are not usually used on 120 volt circuits. Do you mean one switch is a 3-way (Single Pole Double Throw)?
Old 07-27-15, 11:53 AM
I just wanted to change the cover. It looked scary in there. One single pole on the left. Double pole on the right. Double has 3 wires running into it. One one the 3 also run to the single pole on the left. Then finally one wire on the left single runs into the wall. I hope this makes sense. I just want to know if I should call someone to fix it.
Old 07-27-15, 12:04 PM
Yes. Sorry for the terminology
Old 07-27-15, 12:13 PM
It sounds like you have what Ray is describing - a single pole switch and a 3-way switch. Does another switch also control the fixture which is controlled by the one with 3 wires attached?
Also, does everything work as you think it should now and your concern is based solely on what you see inside this switch box?
Old 07-27-15, 12:39 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
I think the feed is stripped in the middle and on the end. If this is your concern there is nothing to be concerned about.
Old 07-27-15, 12:40 PM
Yes. There is another switch downstairs that controls it. For the stairwell light. Everything works yes. The building was built in 1924. So yes I was just wondering if it was ok by how it looked.
Old 07-27-15, 12:43 PM
ray2047's Avatar
For the age it looks fine. The less you handle the wires the better. The insulation can be a bit brittle.
Old 07-27-15, 12:44 PM
pcboss's Avatar
As long as the insulation is in good shape you should be fine.
I think everything is fine.
Old 07-28-15, 01:38 AM
Thanks guys. I will eventually have the place rewired...by a professional.
