Light goes out intermitently
Received 0 Votes
Hi guys,
I'm a recently new home owner, having just bought a 2 family townhouse in New York. I've been enjoying learning more about taking care of stuff, and have my first electric issue.
The unit that the tenants live in have a light receptacle that intermittently just turns itself on and off. There does not seem to be any triggering factor that we can see, and it basically seems to happen at random. Aside from changing a new bulb, we haven't done much trouble shooting. I do have some minor electric experience (changing fixtures mostly), and my first inclination would be to look at the connections at the switch and the receptacle (the light is on the same switch as several other lights, all of which work fine, so it seems the receptacle would be more likely to be the issue).
However, since this is in my tenants space, I thought it would be worthwhile going getting a bit more advice/knowledge before going into their space (to keep the number of trips to a minimum). If anyone has some feedback in terms of what I could be looking for as an issue causing this, I would truly appreciate it.
Thanks!
Thanks!
light receptacle
Do you have conduit?
Received 0 Votes
Thanks for the input.
Sorry, for the vocabulary error... when I said receptacle I was just referring to the connection where the bulb screws in.
These are recessed bulbs, and all the wiring is behind drywall, so I believe the answer to that question is no.
What is a light receptacle?
If these are I/C recessed light's there made to shut off if someone installs to high a wattage bulb in them, to prevent a fire.
There should be a sticker right on the deffuser stating what wattage bulb to use.
I think your first inclination is the most likely to be the case. Bad socket.
Sometimes the connections get dirty. Sometimes the hardware is just cheap.
I have a light in my garage that goes off every once in a while, I haven't gotten around to changing it but if it goes out when I need more light in that particular area I just go tap the lightbulb with my hand and it turns on.
I have to do this every now and then on the garage door opener.
Unreal how cheap some sockets are made, some don't even have full contact at the screw shell, just a tab.
Received 0 Votes
This is extremely helpful guys. Thanks so much.
@joecaption I'm actually remembering a rental apartment I lived in with very similar recessed sockets that also had an issue similar to the one I'm describing here. The solution was a lower wattage bulb, so I'm guessing you might be on to something. This will be the first thing that we look at.
The additional thoughts everyone provided are also super useful. This gives me lots to go on for when I go to work on this.
I'll report back after I've had a chance to check in on this.
Thanks everyone!
Thanks everyone!
Received 0 Votes
@casualjoe and @joecaption, it's looking like you nailed it.
We put a CFL bulb in and it looked to be working just fine when I left. I told the tenant to contact me in case things change, but I suspect we're all set. Great to understand a bit more about how those sockets work, and so glad to see what a simple solution it was on this one.
Thanks so much guys!
