Power randomly goes out but no tripped breakers
For the past week or so we have part of our garage's electricity going out during the day and night. Before I leave for work in the morning it'll be off and then I'll go outside and jiggle the circuit breaker and flip it off and on a couple of times to get it working again. When I come home after work, it's usually off again.
I'm not sure how long it's staying on but my guess is that it's staying on for a while. We have a fridge hooked up and things are staying frozen.
Do I need to replace the breaker?
Welcome to the forums!
If by jiggling the breaker you can get power to be restored, then you might need to change the breaker. However, there is a chance that the bus where the breaker connects might be pitted or damaged. If that is the case then you could relocate the breaker, or worse case, need to change out the panel. You will need to inspect the bus by removing the breaker. (Turn off the panel)
What brand of panel is it? Hopefully not Zinsco or FPE.
I've tried replacing the breaker but that didn't make a difference.
Here's a picture of the panel
I see there are three empty spots on the panel. Can I just move the breaker to one of those and see if makes a difference?
That looks like an old Bryant meter/loadcenter combination with aluminum bus, but I also see some Siemens breakers. I think try to determine who the manufacturer is and then get a new breaker and install it in one of the spare spaces. If the equipment is Bryant, purchase an Eaton/Cutler-Hammer BR series circuit breaker.
