No Power at Irrigation Pump
Old 08-05-15, 06:48 PM
D
My irrigation pump was running fine until it tripped my breaker twice over the course of a few days.
Now it won't turn on at all.
The power is on a dedicated circuit, dual pole 20amp. It comes out of the box to a switch and then in the ground and to the pump.
I used a meter to test the voltage at the pump and it is zero. At the switch, it is a constant 240.
Is it possible to have power at the switch, but no power at the pump and have a happy breaker?
If their is a short in the ground, wouldn't the breaker stay popped?
Thanks in advance.
Old 08-05-15, 07:05 PM
P
Temporarily Suspended
It could have shorted & disconnected somewhere.
Old 08-05-15, 07:17 PM
D
So a short (perhaps a literal ground) would not permanently pop the breaker?
Old 08-05-15, 07:24 PM
ray2047's Avatar
How did you measure voltage?
Old 08-05-15, 07:39 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
Did you check for voltage on both sides of the switch ?
Old 08-05-15, 09:03 PM
D
I checked the voltage with a volt meter. The switch on both sides measured 240 when on, zero on one side when off. When I checked the pump (at the connection) I got zero or nothing. At the pump I checked the wire itself as well as the connections.
Old 08-06-15, 06:23 AM
ray2047's Avatar
If you have 240 volts it isn't the breaker. Does it run if you bypass the switch.
Old 08-06-15, 08:54 AM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
I'd replace the wiring between the switch and the pump.
Old 08-06-15, 02:17 PM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Sounds like the wiring between pump and switch,is it in pipe?it could be a high resistance ground in which case it may not trip the breaker.
Geo
