Replacing standard receptacle with GFCI
Old 08-10-15, 11:02 AM
W
I have this older receptacle in the kitchen near the sink that isn't GFCI and I wanted to replace it with one, when I tried I couldn't figure out what wire to put where since there's 2 live wires (red and white marked with black electrical tape) and one neutral. The red and neutral come from the same wire (12/3) and the white marked with black electrical tape is from another wire. The black wire from the 12/3 is wire-nutted to other black wiresThat receptacle must power another one, which I swapped out for a GFCI with no problem.
Size:  24.2 KBName:  image.jpg
Old 08-10-15, 11:20 AM
pcboss's Avatar
Received 181 Upvotes on 159 Posts
You will not find a gfi receptacle rated for use with aluminum wire.
Old 08-10-15, 11:27 AM
Z
Received 407 Upvotes on 362 Posts
Canadian code requires split circuit receptacles in the kitchen. This basically means (at least) two circuits in the kitchen with the top of each receptacle being circuit 1 and the bottom being circuit 2. This prevents the use of standard GFI receptacles in the kitchen.
I'm not fully versed in the CEC, but I think this means you need to use a double-pole GFI breaker in the panel.
It looks like you have another issue though... that looks a lot like aluminum wiring. Aluminum wiring can only be connected to aluminum-rated devices.
Again, I can point you to some US resources regarding aluminum wiring, but I assume they would be similar in Canada:
CPSC Safety Recommendations For Aluminum Wiring In Homes | CPSC.gov
In a nutshell, you can only use Al rated devices, and can NOT splice aluminum to copper without approved connectors (and even so, the only agreed-upon quality connection is COPALUM Crimping, which is not DIY-able and isn't cheap.
Sorry to be the bearer of bad news...
Old 08-10-15, 11:35 AM
pcboss's Avatar
It is possible that the tape is a repair to the insulation.
I think the are using the device to splice the two whites together instead of using an approved splice on the multi wire neutrals.
Old 08-11-15, 04:00 PM
CasualJoe's Avatar
Received 179 Upvotes on 162 Posts
More recent CPSC publications recommend the AlumiConn connector as an alternative to the expensive Copalum system.
https://www.cpsc.gov//PageFiles/118856/516.pdf
CO/ALR devices are also recommended in Publication 516.
